Sessions
Sessions management allows reviewing currently known user sessions and allows to end these.
Screenshot showing Zammads session management
This page indirectly is affected by Session Timeout configurations from security settings.
Zammad will provide the following information:
Benutzer
The user account this session entry belongs to. It can be normal if a user has several sessions in the list. This can be due to changed browser information or if you use e.g. single sign on methods where the user does not use the log off button.
Browser
The browser agent communicated to Zammad.
Location
The anticipated location based on the users IP address. Depending on the IP address the result shown may differ. This option depends on Dienste.
The following information can be shown:
IP address
Either if you set Geo IP services to inactive or you’re using internal IP address which do not provide location information.
Country (or Country + City)
If Geo IP services is enabled only. Depends on how detailed the available IP address information are.
Depending on how long the address is assigned to a specific country the result may differ. Results can be inaccurate - this technically is not an error.
Age
Provides the time when the session initially has been created.
Update
Provides the time the user last used this session to open Zammad. This timestamp is only updated if the user e.g. reloads, not during normal work on tickets.
This timestamp is being used for the session timeout.
Action
Use the delete button to remove a single session on behalf of your user.
