Placetel CTI¶
Limitations¶
If your browser supports
tel
Requirements¶
You need an administrative Placetel account for your organization.
Your Zammad instance must be allowed to communicate to external services.
Placetel must be able to reach your Zammad instance.
- Setup Placetel connection for Zammad
Learn how to configure Placetel to enable Zammad and Placetel to communicate with each other.
Available settings¶
Click the button next to the Placetel
heading to activate or
deactivate this function.
Wichtig
- Endpoint Settings
The here listed endpoint settings are relevant for the integration configuration with Placetel.
- Endpoint
This endpoint will be required for the Zammad integration within the Placetel web interface.
- API Token
You’ll receive this token within the
Web API
menu. Make sure to copy this value, it’s only shown once!
- Call Settings
- Inbound
- Caller ID to block
E.164
format.- Note
- Other Settings
- Shown records in caller log
60 (default)
120
180
240
300
🥵 Potential performance issue
- Phone Extension to Agent Mapping
By mapping your agents extension to their existing Zammad users, Zammad can provide a new ticket dialogue or open the user profile for the agent that picks up the call.
This speeds up ticket aiding, no matter if it’s for existing tickets or new ones!
The agent perspective is described within our user documentation.
You can find your agents Placetel username combination required within ⚙️ PBX → VoIP destinations. Within the „Advanced settings“ section you’re looking for „SIP user name“ and „SIP server“.
Combine these two like so:
<sip-user-name>@<sip-server>
Recent Logs¶
