Slack¶
In order to use this feature, please add a new Slack app to your Workspace.
The App you need is called Incoming WebHooks
Why do I need this feature?¶
bei Ticketerstellung
bei Ticketaktualisierung
beim Erreichen einer Erinnerung
ein Ticket ist eskaliert
ein Ticket ist kurz vorm Eskalieren
Zammad will provide the Ticket title, a direct link to the Ticket, the event type (creation, updated, escalation), the customer, time and the last article that has triggered the notification.
This will give you further options, as you can see e.g. escalating tickets that are assigned to an agent that’s e.g. absent. You can interact faster, as you might see problems earlier (or even before the problem gets one).
Konfiguration der Integration¶
First of all, please go to your slack workspace - go to administration => Manage Apps. If you don’t have an app yet, you can simply add a new one - just search for `` Incoming WebHooks`` and customize the app to your needs.
Choose (or create) the channel Zamma should post it’s information to and press on „Add Incoming WebHooks integration“. If you’re ready, copy the provided WebHook URL and go to your Zammad installation.
You need administrative rights on the Slack Workspace. The link to the app
directory is normally https://[workspace-name].slack.com/apps
To configure the slack integration, log in to Zammad and go to Integrations (System) => Slack in the admin panel.
Here you can choose on what evens Zammad should post information about a ticket to your Slack channel. Next you need to device what groups shall be affected by this, as anybody with access to that specific Slack channel can read at least parts of the ticket this might be a privacy issue, if you select the wrong groups. The username is simply the name that Zammad uses as display name inside the Slack chat. The channel defines the Slack channel the information is being posted in. As last option, you can set a custom icon for posting to slack.
When you’re ready, just hit „Submit“ and enable the integration. Zammad will now post new ticket information based on the trigger you chose. Below the options you have the recent log that shows the latest requests to Slack for debugging if needed.
If you leave the Icon URL empty, Zammad will use the Zammad logo instead. The icon should be a square PNG file.
The result¶
