Fehlerbehebung¶
All of the system’s latest S/MIME activity is displayed in the Recent Logs section.
This log does not include email
sent by triggers
or the scheduler.
For those, check your production.log
Common Issues¶
- I received a signed/encrypted email before I set up S/MIME integration
No problem. Once S/MIME has been enabled and the appropriate certificates have been added, agents will be prompted to retry verification/decryption on matching emails.
- Die 🔒 Verschlüsseln-Schaltfläche ist deaktiviert
Have you added the recipient’s certificate?
Are you sure the recipient’s certificate is valid?
Have you checked your
production.log
for more details?
- Die ✅ Signieren-Schaltfläche ist deaktiviert
Have you added both the certificate and private key for your organization?
Does the email address on the certificate match the email address of the agent/group composing the email?
- Error: “Fingerprint already taken”
Are you sure you haven’t added this certificate already?
- Error: “❌ invalid byte sequence in UTF-8”
Please ensure to provide PEM formatted certificate and keys.
Did you check if the provided file is a valid certificate or key?
