Troubleshooting¶
All of the system’s latest S/MIME activity is displayed in the Recent Logs section.
Logs report the status and details of all mail, both incoming and outgoing, that used signing/verification or encryption/decryption.
This log does not include email
sent by triggers
or the scheduler.
For those, check your production.log.
Common Issues¶
- I received a signed/encrypted email before I set up S/MIME integration
No problem. Once S/MIME has been enabled and the appropriate certificates have been added, agents will be prompted to retry verification/decryption on matching emails.
- The 🔒 Encrypt button is disabled
- Have you added the recipient’s certificate?
- Are you sure the recipient’s certificate is valid?
- Have you checked your
production.logfor more details?
- The ✅ Sign button is disabled
- Have you added both the certificate and private key for your organization?
- Does the email address on the certificate match the email address of the agent/group composing the email?
- Error: “Fingerprint already taken”
- Are you sure you haven’t added this certificate already?
- Error: “❌ invalid byte sequence in UTF-8”
- Please ensure to provide PEM formatted certificate and keys.
- Did you check if the provided file is a valid certificate or key?
