Sipgate (sipgate.io)¶
Limitations¶
If your browser supports
tel
Requirements¶
You need an administrative Sipgate account for your organization.
- Zammad requires a
sipgate.io
addon from the feature store.
Beachten Sie bitte, dass API-Aufrufe bei Sipgate nicht kostenfrei sind. Kosten können entstehen und von Account zu Account unterschiedlich sein.
Your Zammad instance must be allowed to communicate to external services.
Sipgate muss in der Lage sein Ihre Zammad-Instanz zu erreichen.
- Setup Sipgate connection for Zammad
Learn how to configure Sipgate to enable Zammad and Sipgate to communicate with each other.
Available settings¶
Click the button next to the sipgate.io
heading to activate or
deactivate this function.
- Endpunkt-Einstellungen
Below endpoint settings affect the sipgate.io configuration.
- Inbound
This endpoint is required for incoming call hooks.
- Outbound
This endpoint is required for outgoing call hooks.
Wichtig
- Anruf-Einstellungen
- Inbound
- Caller ID to block
E.164
format.- Note
- Outbound
In many cases you may want to use a different caller ID depending on the destination you’re calling. This may apply due to specific connection rates to other countries or because you want your customer to feel you’re calling from the same country.
This option expects
E.164
number formats.- Destination caller ID
The caller ID or number you’re trying to call.
You can use wildcards for e.g. country specific outbound numbers like:
49*
for Germany4930*
for Berlin / Germany landlines33*
for France
- Set Outbound caller ID
The outbound caller ID to set (the number your customer sees on his display) in
E.164
number format.- Note
Provide a short description for fellow administrators.
- Andere Einstellungen
- Default caller ID for outbound calls
This option expects
E.164
number formats.
- Shown records in caller log
60 (default)
120
180
240
300
🥵 Potential performance issue
- Phone Extension to Agent Mapping
By mapping your agents extension to their existing Zammad users, Zammad can provide a new ticket dialogue or open the user profile for the agent that picks up the call.
This speeds up ticket aiding, no matter if it’s for existing tickets or new ones!
The agent perspective is described within our user documentation.
You can find your agent’s Sipgate username within
Accountverwaltung → Benutzer
. You’re looking for the SIP-ID.Bemerkung
Users with several devices also have several SIP-IDs.
Recent Logs¶
x
Fehlerbehebung¶
- My Phone page stays blank, signalling does work…
