Fehlerbehebung
All of the system’s latest S/MIME activity is displayed in the Recent Logs section.
Sample entries of in- and outgoing S/MIME related emails.
Logs report the status and details of all mail, both incoming and outgoing, that used signing/verification or encryption/decryption.
This log does not include email sent by triggers or the scheduler. For those, check your production.log.
Common Issues
I received a signed/encrypted email before I set up S/MIME integration
No problem. Once S/MIME has been enabled and the appropriate certificates have been added, agents will be prompted to retry verification/decryption on matching emails.
Screenshot of user prompt to retry decryption
Die 🔒 Verschlüsseln-Schaltfläche ist deaktiviert
  • Have you added the recipient’s certificate?
  • Are you sure the recipient’s certificate is valid?
  • Have you checked your production.log for more details?
If encryption doesn’t work in the composer, it won’t work in triggers or the scheduler either!
Die ✅ Signieren-Schaltfläche ist deaktiviert
  • Have you added both the certificate and private key for your organization?
  • Does the email address on the certificate match the email address of the agent/group composing the email?
Error: “Fingerprint already taken”
  • Are you sure you haven’t added this certificate already?
Error: “❌ invalid byte sequence in UTF-8”
  • Please ensure to provide PEM formatted certificate and keys.
  • Did you check if the provided file is a valid certificate or key?
