CTI (generic)¶
Limitierungen¶
If your browser supports
tel
Requirements¶
A telephone system that supports webhooks (outbound) (best option are those that allow customizing the calls).
A unique Call-ID during the call session.
Call event data (both numbers and direction).
Your Zammad instance must be reachable for your telephony system.
If you want to learn more on what kind of requests are supported by Zammad and what it expects, please consult our CTI-API documentation.
Available settings¶
Click the button next to the CTI (generic)
heading to activate or
deactivate this function.
- Endpunkt-Einstellungen
Zammad will list your generic CTI endpoint here. It contains a unique token so ensure to keep this URL save.
You’ll need this endpoint for your PBX to talk to Zammad, see CTI-API documentation.
Wichtig
- Anruf-Einstellungen
- Inbound
- Caller ID to block
E.164
format.- Note
Your telephony system has to support this function. Zammad will send a
reject
response which will cause your telephony system to hang up the call.To callers this usually will feel like the line is busy.
- Outbound
In many cases you may want to use a different caller ID depending on the destination you’re calling. This may apply due to specific connection rates to other countries or because you want your customer to feel you’re calling from the same country.
This option expects
E.164
number formats.- Destination caller ID
The caller ID or number you’re trying to call.
You can use wildcards for e.g. country specific outbound numbers like:
49*
for Germany4930*
for Berlin / Germany landlines33*
for France
- Set Outbound caller ID
The outbound caller ID to set (the number your customer sees on his display) in
E.164
number format.- Note
Provide a short description for fellow administrators.
This option requires your PBX to send a specific request to Zammad before dialing. Please consult the CTI API in case you’re not sure.
- Andere Einstellungen
- Default caller ID for outbound calls
This option expects
E.164
number formats.
- Shown records in caller log
60 (default)
120
180
240
300
🥵 Potential performance issue
- Caller Log Filter
This function allows you to provide call information based on e.g. queues only to agents that really need the information.
Why? If you have a team for several countries or departments, you don’t want to bug your agents from other departments. Leaving these options empty will fallback to showing everything to everyone.
- Destination caller ID or Queue
This depends on your PBX and usually is either a queue ID, phone number or extension.
- Agents
Select the agents that are responsible for the group. These agents will then see caller log entries and call notifications fitting to said queue.
Recent Logs¶
x
Fehlerbehebung¶
- My Phone page stays blank, signalling does work…
